Lowering kit is lower than expected... issues!!
plckidd
Ohio
Beautiful truck! I too also like that rake, I would personally leave it and modify the inner fender wells for your issue. However, you have to be happy with it so if you want to raise that front a bit for the look you want, do it!
No matter what you decide, that truck is awesome!
Hey thanks man!! I ordered a set of Slosh Tubz today. That will fix the issue.
eskimomann209
Modesto
Marcus
I always like the parts these guys offered.
I’ll probably install these to cover up my wiring. Dunno if they’d help someone with wheel clearance issues.
plckidd
Ohio
What the hell's wrong with air shocks or mullets?
Young folks nowadays want to shave the sides of their heads and have an explosion of unruly **** on top. I don't understand it any more than they understand my mullet.
And in the right situations, air shocks are OK. Not the best usually, but OK.
So true bro! I’m still old school and still like t
I bought mine back in July, I think, but haven't installed them yet. Let us know how the installation goes when you get them.
you got it! I should have them installed by end of April.
rt66paul
California
paul
1991 suburban
It is not like I wanted "business in the front, party in the back", but as my fourhead turned into a sixhead(fingers above my eyebrows), that is what happened. So, who knew that a mullet was just male pattern baldness?
MikeB
Hopefully, but they won't help if the tires are rubbing the fender lips on turns.
That's an expensive fix! 1-inch taller springs would solve both the inner fender and fender lip problems.
Big Chip
Michigan
Kevin
C35
Mine is lower and I have no issues with the tire hitting the fender lip so I imagine he'll be fine.
GTP51
Melbourne Australia
Geoff
R10 Silverado half ton Stepside
Mate, you posted in another thread saying you had to jack up the control arms to be able to connect the shocks, a couple of us answered you there.
your problem could well be just as simple as the shocks are holding down the front of the truck and it’s not safe to drive it with shocks without any rebound capability.
Salty Crusty
Gary
c1500
^ I doubt that this is the issue, I've lowered several with stock shocks and they never limited rebound.
It's an easy theory to test, though - disconnect the top of the shock and see what happens.
Regardless, you should buy some new shocks built for the correct amount of travel.
Catbox
Peter
C20 Silverado Camper Special
At that point it is called a "Skullett"
plckidd
Ohio
That sweet! Very clean looking and smooth. Thanks for sharing!!
plckidd
Ohio
Yep. that's true. And 1" taller springs is certainly not out of the question. The tires do not rub the fender lips.... but it is very close! I could roll the lips, but I am taking one step at a time.
plckidd
Ohio
Could you post a pic of your truck? What size are your tires/wheels on the front?
plckidd
Ohio
Yeah I did. Thinking I had 2 separate issues. Tom at Switch Suspension told me to put the wheels on the truck and get it onto all 4 on the ground. Then measure center of shock mount to center of shock mount (top to bottom). I did what he asked and I even told him the shocks were too short. He said this is what McGaughy's ssells for their kits. I called McGaughy's and pretty much same song and dance. If I were to do it over... Western Chassis all day long. Would not recommend McGaughy's. Shocks are measured mount to mount with the suspension relaxed while on a lift.
garsy21
