Lowered c20 suburban and rake
txaggie
austin texas
kris
suburban C20
Ai copilot is telling me to remove the lowest shortest spring so that I don’t change pinion angle or create other problems
Moderator
Eh.
The shortest one might not change much. It also might have a centering wrap (forget the actual name) attached to it.
Can you get some pictures of your rear springs?
txaggie
austin texas
kris
suburban C20
Eh.
Here are the leafs with the helpers removed. Also this image really illustrates the 3 inches of rake:
Moderator
Yeah, definitely don't remove that bottom one. I'd start with the 3rd on on the bottom, since the end of it appears to be in close proximity to the adjacent leaves, compared to others. If you choose to remove a 2nd leaf, choose it based on keeping consistent leaf end spacing.
Moderator
Do you still tow that big camper?
  • Like
Reactions: WFO
txaggie
austin texas
kris
suburban C20
I guess we are going to pull a leaf this week. Hopefully this doesn’t create any axle wrap or pinion angle issue.
Moderator
duncan_schawalder
