Light trouble
larecords
CA
larry
Scottsdale
I have no tail lights or side lights or instrument lights. Signals, four way and brake lights work.
Light switch is good all fuses are good.
Not sure what is wrong?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Presumably if you had none of the above, you'd also have a lack of headlights since I believe all of them are on the same circuit when you pull the handle; is that true as well?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Historically, headlights have been on a priority circuit, independent of the tail lights.
If no tail lights is the only issue, start checking all wire connections and verify there is power at the fuse block where the tail lights/instrument lights fuse goes.
Turbo4whl
Downingtown, PA
Wayne
Did you test the fuse with a test light or meter? Fuses can look good and still be burnt out.
WP29P4A
Nevada
Sierra Classic V1500
Trailer wiring seems to keep popping up as a cause of lighting issues on these trucks, the other most common one seems to be bad grounds.
larecords
CA
larry
Scottsdale
Thanks haven't looked at trailer lights
larecords
CA
larry
Scottsdale
Headlights also work meter tested all fuses and light switch
Turbo4whl
Downingtown, PA
Wayne
Then you have an open connection between the fuse block and the headlight switch. Could be the connector on the headlight switch, (easy to check). Or the connection on the back of the fuse block. That wire goes from the fuse block right to the headlight switch. If someone tapped off that wire for something else, that added connection could be bad.
Misty Blue
