Lifter valley oil splash shield in a BBC
Mike Harrington
Briggs,Texas
I'm putting a new cam in my 454 TBI engine and when I removed the intake manifold I noticed it did not have the sheet metal oil splash shield that keeps hot oil from getting on the underside of the intake manifold. I'm not talking about the one that rivets to the bottom of the intake...im referring to the one that lays down inside the lifter valley.... GM part number 12555320. Is this some thing I should install in the engine even though there wasn't one to begin with?
Mike Harrington
Briggs,Texas
Is there an actual benefit of putting one in there? The part number I gave is an actual GM part so they might have had an afterthought?
nvrenuf
Mobile, Al.
I’ve never seen on on a gen IV bbc. I can’t imagine you’d see much benefit unless it’s a high hp motor that you’re racing.
Shorty81
Baby Boomer
North West ohio
Darren
My BBC is a 1976. It does not have a splash shield.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
I agree with Andy, never seen one. Haven't opened up too many BBC's but I did have an LS6 in my Chevelle and it never had one. If Chevy used them anywhere. you would think it would be in that engine!
Supporting Member Army
It is OEM on the Gen VI Vortec 454... I had one on the donor 1997 K2500 454 I opened up when I sent it off for rebuild.
Markmx6
Phoenix
Mark
C3500 dually
My gen 6 motor had one too.
I don't think it would hurt to have. It may not really help though.
I agree. It may or may not help. The Gen VI is MPFI, and has no exhaust crossover to heat the intake, so having the heat shield makes a lot of sense to keep the intake manifold colder. With aa Mark IV or Gen V having the exhaust crossover and fuel injected before the intake, i'm not sure if it would help or hurt it. There is also a supplemental oil cooler, roller cam, and it runs 5W-30 from the factory.
Catbox
Peter
C20 Silverado Camper Special
You can see the mentioned valley pan in this photo of my Gen 6 454.
It just lays in the valley.
I would think it would be a benefit to keeping things cooler on the intake in any build.
Mike Harrington
Briggs,Texas
Catbox...yes that's what my understanding of the purpose of the shield is.....to keep the hot oil from splashing up on the intake and heating the fuel and air mixture up. The intake I have right now is the stock TBI intake that doesn't have any kind of plate that's riveted on the bottom of it like the intake on my generation IV does. So maybe that full length oil shield over the lifter valley would be beneficial in this case. I guess I'll go ahead and put one in there and see how it plays out
nvrenuf
Mobile, Al.
How is the gen VI valley pan secured? Is it part of the intake gasket? If it is, need to be sure all of the holes line up correctly if you’re using it on an older gen block.
Mike Harrington
Briggs,Texas
The block is a gen VI but it's set up for hydraulic cam and such not roller. It has provisions for roller but just not used.
nvrenuf
Mobile, Al.
Do you mean flat tappet?
What roller provisions? Unless a gen VI is very different from a IV the lifters only have link bars joining pairs as opposed to the big spider-like retainer that (I think) small blocks use.
A Gen VI is very different from a IV and has the same hydraulic roller provisions as the Vortec small blocks got. It has the cam thrust plate on the front of the cam and the lifter Valley is tapped for the same style of retainers and spider assembly as the small block vortecs. The cooling passages, oil galleys, and several other things are different as well. The timing cover only has 6 bolts, all of them are 4 bolt mains, and it is a one piece main seal.
Malo83
