Got the engine harness mostly done. Taped with 1" non adhesive tape.
And in place. The routing is not my typical jogging across the intake in-between the distributor and oil pressure port, but with the throttle linkage exiting the firewall where it does, that keeps things away from harms way, or should.
Past the starter trigger wire is the charge wire, voltage sensing wire, and thermostatic ground for electric fans, they will be joined up with the main battery cable to the starter and run together to the new panel on the inner fender.
The firewall I will be making or finding a good sealing grommet for. I would have liked to have done a bulkhead of some kind, but wasn't able to find one that I thought would have worked and that I liked.
I did pull the distributor for better access at the rear of the engine, I initially had thought it was an MSD ready to run, it is infact a clone of one to some extent.
