Legopnuematic’s Shop Projects
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Ya know I was showing Georgia all these pics of the new moapaarre and she says " doesn't look to bad....at least the doors are still on it" I have taught her WELL!!!!!!!
legopnuematic
Licensed Junk Dealer
MO
Spencer
Dave the owner of the 57' came by this morning and we talked over what to order, so I will be getting parts moving on their way here. Made up another stand for the 340 to sit on.
Might have a trade worked out for the Scamp? Might end up trading for the 383 big block that was in the wagon at stage right. The purple 65 he runs 10.00 with 50lbs of added weight and a throttle stop to hold that time. Wheelie bars, has run a 9.40 before.
legopnuematic
MO
Spencer
Exciting stuff yesterday, changed the oil in the ram, tire rotation and tire pressure adjustment.
Ordered up a bunch of stuff for the 57, should be able to get things moving along with it this week. I will be wiring up my switch box to get it started for the first time, as that is all still unknown, then if it can start and run and move itself that will be quite nice.
legopnuematic
MO
Spencer
Fuse and relay box arrived today. Seems like it is a nice piece. I intend to mount it on a plate on the passenger inner fender, along with the battery cutoff switch, and alternator fuse.
aasleson
Isaiah 45:23
Minnesota
adam
k30
What is your favorite crimper for that style terminal?
legopnuematic
MO
Spencer
I have found that I use a variety of crimpers for open barrel terminals.
I have a cheap ratcheting crimper that I had to modify the jaws (milled one down to clear the tangs on some Packard terminals), I use for doing Packard style terminals mostly. I have S&G tool aid weatherpack/metripack crimper and their Deutsch open barrel crimper. A Mac open barrel crimper and another ratcheting crimper that came with the Molex micro fit connector kit I had purchased.
The ratcheting set works good for Packard type stuff as that extra leverage helps out a lot on these pre-arthritic hands, they can be quite stout terminals (especially compared to a weatherpack or AMP type terminal). On the lighter terminals not great, tend to smash more than roll.
So the answer is all of them. I’ll get some pictures of the fleet when I’m at the shop next.
legopnuematic
MO
Spencer
I like that fuse box! I might have to order one for my truck, I'm not happy with my current setup
My initial impressions of the box are pretty good. It’s a nylon reinforced plastic and does have a good feel to it. IP65 rated. You can purchase it bare, as a kit (what I got), or “pre wired” (pre terminated with short leads), $25 for the kit which I think is not bad at all.
I think it should make for a nice solution for an underhood box, it will be used for headlight relays, hi and lo, electric fan relay, heater valve relay and compressor clutch relay and potentially fuel pump if we keep the electric pump (as a backup, not primary).
aasleson
Isaiah 45:23
Minnesota
adam
k30
Thats the same box I used on my cucv for plow lights, aux reverse lights, and fuel pump. If i were to do it again I think I'd save myself the time and do the pre wired version.
legopnuematic
MO
Spencer
Any concerns or issues with the box on your install?
It is 100% a me thing/me issue, but I have a growing preference towards using non prewired/pigtailed things if possible. Functionally I know that a good splice isn’t going to be an issue, I like to avoid a bundle of splices if I can. Really more of a visual thing than anything else. That and it seems to never fail that things end up just short to have a splice-less home run with pigtails/prewired stuff.
Like I said, it’s a me thing lol.
aasleson
Isaiah 45:23
Minnesota
adam
k30
Not with the box, I got their switch box and I'm having some issues with that. The terminals they send with the relay/fuse box are a on the chinsey side and I don't like that you have to run the wire through the seal and then put the terminal on but I guess I'd rather have it fully sealed.
I totally understand that's why I ended up getting the non wired version as well
legopnuematic
MO
Spencer
Parts and materials have arrived. Summit, CE auto electric, and rock auto
I did some cad to start figuring out a filler panel/mount for the battery cutoff switch, fuse and relay box, along with the alternator mega fuse.
Cut out and getting ideas on mounting.
This 16 gauge (a little thicker than it really needs to be) was leftover from making the bedside toolbox for the 76 back in high school. It was about the right shape in the leftover piece. Trimmed it to fit with the bandsaw and shear. The large grommet will be the battery cable in, smaller grommet will be from switch to fuse, once I get the panel mounted to the car I will locate the fuse/relay box and then mill a window out for it.
legopnuematic
MO
Spencer
Crimped a lug into the new battery cable (1awg tinned)
Added Molex MLX connectors for the cluster. The four pin is for the engine harness (gen light, oil pressure, and temperature sender), the 9 pin is for the dash stuff (turn signals, high beam, panel lights, ignition power, fuel sender).
The oil light will be operated similar to how the gen light works, it will be fed ignition +12v, at the oil pressure switch I'm adding, teed to the choke wire, it will ground when the switch is open through the choke, but when the switch closes with pressure it loses the ground and goes out and powers the choke. Basically wiring that the same way a square with a dummy light and electric choke are.
Here's some of the crimpers I have as I said I'll snap a picture. There's more, but these are the most relevant.
Going to need an 1/8npt extension. The autometer sending unit is gigantic. Normal oil pressure switch for choke and light.
legopnuematic
MO
Spencer
The Dakota digital sender for reference, teeny tiny.
Mhmm, pigtailed... Trinary switch for compressor and electric fan operation.
Stopped on the panel as I need to beadroll an flange on the top and down the front side to get it to sit nice. I do not have my bead roller dies at the shop.
So I went to grab my box of rivnuts from home and the box tore and rivnuts everywhere.
This box was 3/4 full of 10-32 and 1/4-20 riv nuts. Spent too long cleaning most of them up. They went everywhere, including my shirt pockets.
doo-daa
