WP29P4A
- Jul 18, 2021
- Nevada
- Mike
- Sierra Classic V1500
- 350 TBI
I had to replace the battery in the Charger, 10 years old and started to have issues holding a charge. Figured I would get a quality (expensive) battery. Got a new red top optima battery, put it in the freshly restored engine compartment, and it leaked, about a 1/4 cup. All over the new powder coated battery tray, sprayed on the new radiator and the new engine compartment paint, then dripped on the garage carpet and started melting it, could hear the carpet bubbling.
I had to scramble to get the car out of the garage, douse the area with baking soda, cut out the acid soaked carpet, rinse everything down, dry everything, get the car back in the garage, then return the battery to the store (Autozone) for replacement. Got a new replacement, got it in the car, everything seemed to be fine, and then suddenly.
I just noticed a small amount of leakage on top, no sizable puddles like the last one. These things are supposed to be leak proof to the point where you are supposed to be able to mount them on their side without leaking. I charged it up fully on a new charger with the AGM mode before putting it in the car, no issues, I moved the car out of the garage and warmed it up for less than 5 min, barely lifted the temp gauge, then pulled it back into the garage a couple hours later, still fine.
Just went out to finish up a couple projects and noticed the wet on top of the battery. This is Nevada, if it was water it would evaporate in less than 30 min. Anyone have any experience like this?
