knob removal
crpntr78
Missouri
Have a question (not sure it's in the right thread) I'm needing to change out a fan speed switch on my A/C, heater assembly but can't get the knobs to come off. Other than just pulling, with no result? Anybody here with a trick for that? Thanks
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
My 80 does not have a knob for the blower, but does for the mode selector and temp slide.
Don't remember having to take those off, though - take the dash bezel off and take the ac switch out of the dash.
Seems like the blower switch was just held in place by a couple of screws to the main ac switch.
Britt
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
If just the fan speed switch is being changed, you can crawl up under the dash. If you have a/c remove the vent tube, I think I had my radio out when I did it so that may help but you can access the screws on the back, then the knobby guy on the switch does just pull off, it’s just really tight on there. You can try to rock the knob in the same line as the switch and pull it off
crpntr78
Missouri
Okay, thanks for the replies.
You're talking about these right?
If so, there is no trick to getting them off. You just have to go Neanderthal on their asses. I wrap them with a little piece of rag (to protect the finish), grab on with a pair of Channelocks and then pull/wiggle on it. It will eventually pop off. Wiggle it parallel to the wide surface.
crpntr78
Missouri
Thank you Mr. Chengny, that's exactly the information I was looking for.:)
