Keyed the same ignition switches
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Any body ever heard of such? Do they exist? Can a feller find them?
Be awful nice to have.
Thanks guys
Shakey
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
If the ignition is wore out, multiple keys may work. I always keep all my old GM keys and go through them when I have something I don't have a key for usually one works.
I understand that's not really what you're asking for
Lock mechanism on these trucks is simple, and a locksmith can usually rekey them very quickly to match whatever you want. I used to go to a pick and pull where the guy pulled up a mobile truck each day and rekeyed locks for folks buying stuff from the yard.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
So the right locksmith can make it where 1 key would start, turn the ignition, on say 5 vehiceles?
SDJunkMan
Black Hills of South Dakota
Jeff
Should be no problem. I've been told that all CUCV's use the same key. Not sure if that is true, but it explains the chain and padlock bolted under the drivers sear of mine:)
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Guess I need to find a locksmith.
BKING33
York Springs, PA
K30, Suburban
6.2, 6.2 turbo
Yes all CUCV use the same key for all locks. That's the first thing I changed on mine.
As far as recoding the ignition I've never done one. They are serviced by a new precoded cylinder.
The door locks can be recoded to whatever u want. Have had many recoded at the dealer I work at.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
So... where can I get 5 or 6 CUCV ignition key switches?
Don’t make this harder than it needs to be.
If you have a key for each ignition, just pop out the switch (check the repair manual for the method) for each truck and take all five to a locksmith. Pick your favorite key and have him/her key all the switches to match that one. I don’t know how much they will charge you, but it’s a quick, simple job if the lock cylinders are out of the trucks.
I have rekeyed locks myself, but you need an assortment of pins so that you can make every pin position match in each lock cylinder. Locksmiths also have decoder that they push in the locks and it tells them the key code to use.
Craig 85
Nashville, TN
454/TH-400/NP205
Most older GM cars have this key coding. The square ignition key usually has one type of code and the round door key will have another. The codes changed every year. See the link for the breakdown. Back in the day we had 1989 Caprice patrol cars. The ignition and doors were keyed using a single round key.
Lets say you have an "A" ignition key, you will need "A" ignitions for all your vehicles as the profile needs to be the same for the key to fit. Napa and others carry replacements. You need to just buy ones with the same code.
http://www.carlocksandkeys.com/blog...-motors-lettered-square-and-round-key-blanks/
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Cool, Thanks!! I will see about rounding up some like lettered tumblers and a locksmith.
Appreciate the info!!
Smitty69
