Keep blowing ignition module. Will MSD box make this stop??
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
I know I post this last year. But I have still not fixed this problem.
1. new wires
2. new spark plugs
3. new cap and rotor
4. New coil
5. new ignition module
6. replace dizzy with a good working GM 1
7. new alternator
Just about everything needed. Yes I used the paste so the module would not heat up, and yes I cleaned all the old paste off before I put the new paste.
After all this new stuff, 2 min, later it blew the module again. GROUNDS ARE GOOD AND CLEAN ..
Will a MSD box with a external coil make this NIGHTMARE go away???
I am really lost what to do here.
The only other thing I can think of is the ignition box on the steering column. Could those go bad or create a short to blow out the modules??
engine is a 5.7 auto.
That truck looks familiar... You don't happen to own a Camaro too do you? lol
Nasty-LSX
TogetherforeverCovid19
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
The truck was for sale at 1 time!! Might have been how you seen it. :)
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
update. Starting taking stuff apart to put a new module in. Here is what i found.
If Im correct, there should be a metal ground tab in the cap correct?? Looks like a hook end for ground? Nothing here.
Then i noticed the tach wire had a slit in it. (unplugged externally)
See the white looking soot on the black coil. It was all over the wires close to coil also..
You see the spring in the center!!
it looked funny, so I pulled it out, WTF!!! :shrug: I never seen one broke. you cant force these in or put them in wrong. SO WEIRD..
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
Seems the ground prong is missing!!
Georgeb
Wisconsin
George
K10 Burb Z71
That may be your issue!
4WDKC
Southern Florida
Kacy
I had a similar issue one a different car, switched out dist. and its fine. Leads me to believe my issue is the pick up.
K5Chris
