K20 c6p rear axle questions
string-a-ling
Aris
K20 Scottsdale
How y’all doin? I’m new here and I have a question regarding my ‘86 C6P code k20.
Im led to understand ‘81 and up 20 series trucks with the C6P code have some similarities to the 1 ton crew trucks as far as frame thickness, brake size, spring length etc… My question is, are the axles in the 1 tons (including dually axles) direct swaps for my truck? Mine has a SF 9.5” 14 bolt in it and I make frequent use of a gooseneck and I’d feel a lot better loading it down knowing the wheels won’t fall out of it if I break an axle. Also if it comes to a task that potentially outclasses it with the SRW I’d sooner swap a dually axle in it and swap a bed than buy another truck. I’ve put a lot of work into it and am pretty attached to it.
If this question has previously been answered, please feel free to direct me to the appropriate thread! Thanks in advance! Pic for interest!
Craig 85
Nashville, TN
454/TH-400/NP205
One ton's are not direct bolt in. Shock mounts are opposite and spring pads are more in board. See my K30 SRW 14 bolt below. A 3/4 ton 14 bolt FF is a direct bolt in though.
If you add a FF rear end, you will need to lengthen your drive shaft. The 9.5" has a longer snout.
Washington
And another question answered with great knowledge!
I sound like a broken record but this forum and the folks are a great resource.
@string-a-ling, I’ll add, if you’re hauling more payload than a 14bolt FF will handle with appropriate rims and tires, you’re basically overloading the absolute crap out of a very nice truck. Probably to the point that other damage is imminent.
Find ya a srw 14bolt FF and it will be reliable with 2 tons of payload or pin weight and won’t tear the truck up as long as you use some common sense when loaded real heavy.
Nice truck btw!
SquareRoot
YUP^^
I put a 14FF out of a CUCV in my 85 K20. Had to relocate the spring and shock mounts. Wasn't a big deal if you have the tools. I highly recommend replacing the factory u-bolts/plates with the ORD ones. Not only do they flip the u bolts to the correct orientation and are much more robust they allow you to move the axle fwd/back an inch. This will make up for the driveshaft length Grit dog mentioned. However, I ran my FF in the original position and never had an issue with it being to short.
1980* but yes. A c6p axle will ensure its only ratios above 3.73 (4.10 and 4.56 i think) and the brake drum is 13 inches not 11 like non c6p axle. The axles are the same otherwise to my knowledge. Full floaters that is. The shock mounts MAY differ , only if thats required for the "HD" larger shock absorbers. if they bolt in place of eachother then ignore that. also there are other quirks but for your question that should help a bit
string-a-ling
Aris
K20 Scottsdale
Thank y’all for the insights. Admittedly, I was just curious as far as the 1 ton and dually axles go. I’ve already acquired a FF 14 bolt out of an 84 or 85 k20 with the correct mounting surfaces all around and am currently hoarding fresh suspension parts and disc brake conversion parts so I can slam it all together in one sitting However, on the subject driveshaft length, I just finished up a 6.0/nv4500 swap in this truck. I re-used the trans x-member so I’ve already lost 1/8” or so to the shorter transmission. Will probably have to call the driveshaft shop when I get around to making the swap happen.
string-a-ling
Aris
K20 Scottsdale
84 or 85 k20 didn't get a ff
the k30 did
might take a look at that acquired axle.
good luck!
Maybe it’s from an earlier truck. I’ve seen 70s 3/4t trucks with em. Everything seems to measure out the same. And the shock mounts are in the correct place. Guess I won’t know for sure till it all goes together. Thanks for the heads up!
WebMonkey
Missouri Ozarks
sounds right!
they definitely put the ff in the 3/4 in the earlier trucks.
it'll be sweet regardless
(the only thing i would get hung up on is the switch in parking/e-brake backing plates that changed from earlier to later trucks)
string-a-ling
Aris
K20 Scottsdale
sounds right!
I’m goin to discs. Currently hunting for a caliper with e-brake functionality that fits. I’ve heard tell of a Caddy caliper that apparently fits, is robust enough for the application and has an e-brake in it but haven’t had time to follow the lead. Worst case my factory axle has the big drum on it so I’ll see if that works.
The wheel end parts for a k30 srw I think should match if you wanted to put a 13 inch drum on your ff
Do you have slide on drums or is the drum retained kinda like a front hub with bearings is
string-a-ling
Aris
K20 Scottsdale
Its the early style that’s retained by the axle shaft bolts. I’d be interested to know what disc brake assemblies from more modern 14 bolt axles if any fit. I like going to the junkyard for stuff.
No it’s not. Unless you mean the semi float. The axle shaft bolts are holding the ff shaft, behind it are spindle nuts I think you meant.
If you wanted a more modern 14 bolt the aam 11.5 or whatever gm used into the 2000s I think is relatively easy to adapt to a square iirc.
WFO
Texas Panhandle
the k30 did
good luck!
My 86 came with a full floater. It's C6P optioned though.
string-a-ling
Aris
K20 Scottsdale
Mine's a C6P as well. Ive wondered why it didnt have a FF since i figured out what C6P meant. Maybe because its a 4x4?
Dan87r10
