flyboy1100
- May 23, 2014
- UsA
- me
- k1500
- 305, 700r4??, 3.42 gears
Just picked up this '86 k1500. it needs some TLC, probably won't ever restore it, but have plans to fix it up to a dependable driver that I can use for years.
this truck had been sitting in the weeds for probably 6-7 years before my cousin bought it last year, and I just bought it from him.
more than 100K, could be 173k, 273k, 373k??? no idea, but i found a reciept in the glovebox from 20 years ago with 84,000 miles on it, so it has to be over 100k.
needs:
-windshield
-drivers side vent window glass frame (bent not sure how to rebend if at all possible, glass is good)
-window seals, passenger side is pretty much missing
-dash lights don't work, no power at fuse (original fuse was blown, replaced but no power, hmmm)
-possible rear main seal leak, maybe oil sending unit, not sure. already fixed -leaky valve cover.
-seems like lots of blowby since now there is oil being pushed passed grommets for oil fill tube and breather tube
-rear differential whine, at least from my understanding of it.
-some body work and interior work, but overall pretty clean, not much rust, rare since it is a ND/MN truck. frame looks great
i was surprised to find out it had 3.42 gearing, no idea if OD is working, most of the vacuum lines and electrical connections on the carb have been disconnected.
going to test engine compression tomorrow, maybe do drivers side valve cover if the compression is ok.
here are the pics.
needs:
-windshield
here are the pics.
