Is blower motor supposed to be off when off?
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
When I have my slider switch in the off position, my blower motor still runs in the lowest setting. Is it supposed to do this, or should it actually be off?
Also, I have a 4 speed options for the blower, and only 3 work. "Hi" doesn't work at all. Any thoughts as to why the other 3 speeds work, but not the 4th?
Thanks in advance.
Brandon
kdo58
Puyallup wa.
k5
yes it suppose to stay on
Moderator
Yeah, the 70's A/C trucks have the blower on all the time. There is a relay mounted near the blower motor that triggers high speed.
chengny
2 X what David says. The blower circuit is designed to always run the fan. Even with an A/C equipped system, moving the mode control arm to OFF only blocks most of the air from entering the cab through the vents:
I have a thought why. The most common cause of one (or more) blower speeds being unavailable is a failed coil(s) in the blower motor resistor stack.
87scotty
Central il
Andrew
V20
5.7 for now
Occasionally a melted plug but yea somthins burnt up
Moderator
IIRC, high speed doesn't pass through the resistor. The resistor is there to slow down the blower for the different speeds, you don't want the blower slowing down to get high speed. High speed gets direct ignition 12v through the high speed blower relay.
chengny
Yep, you recall correctly. The correct answer was...faulty relay - not resistor. That's what happens when you rush when answering a question. Mea Culpa.
Below is the diagnostic chart for a "Blower Inoperative In High Speed Only" - 1973 C/K with Four Seasons Climate Control:
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Gentleman,
Thank you very much. I love this frickin site!
dudleyrushmore
