- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
YOU GUYS CRACK ME UP ON THIS 4L60E CRAP-ALL OF THEM ARE BREAKING AND GOING OUT..but you cant figure out..why they broke..THEY ARE ALL DEFECTIVE
CANT YOU GET THAT..gm spent years trying to straighten them out.even changing to another transmission..the 4l80e.why..the 4l60e.could not be.made right..when you pull one apart.you do not know what is in it..or what has been changed out..
you will have to eye ball each part and look up the upgraded parts.on line.why do you think.they had to come out with all the upgraded parts.for the 4l60e.from front to back
but what will it cost you too..buy each part.it would make more sense.to buy a built 4l80e-it holds more fluid.i would buy that electric cooler set up..i am sure they run high temps..
i do not know.anything about the new ones.if the heat and oiling problems are gone.i am sure.they have every up graded part that could be.put in them.i do not know if they are adaptable..to what we have..
i would put my money..in a built tb400 trans..short shaft.if you get too many rpm,s you can change out the rear gears..
you could get a 4l60e.from some where.strip it down..and it may look good.because.some time before you got it.some parts were replaced in it.will you be able.to tell the new stuff from the old.if you are not a rebuilder.
i bet not.i know one thing..FOR SURE.if you build one.of these defective trans..you better.know what you are doing for real..front to back..do not fail too buy it all..the replacement parts..or you are going to just throw..all your dollars..that you put in it..away.
one little...part-will trash your work..
Hate to say it Wheelie, but you're way off on the wrong foot here. The 4L80-E was not made cuz the 4L60-E was junk. There was no switch to another trans. The 4l60-E is for passenger cars and 1/2 ton trucks, as was the Th350, and the 4L80-E is for 3/4 and 1 ton trucks as was the Th400. And NO, adding taller gears does NOT help your mpg at all in city. A lower gear will get your vehicle taking off from a stop light much quicker. When the Gubment put strickter EPA standards and higher mpg of their total overal fleet, lock up converters came about. Then the overdrive transmissions came about. I will be first to admit that the 700r4 and 4L60-E have their weaknesses, but I'll assure you. One can be built to easily withstand 500hp, and with some work 700hp. You won't get a Th350 to hold up that kind of horsepower right out of the GM box either. I see your point, but I think your pushin over the deep end.
