Intermittent Wipers
83kid
Massachusettes
Hi,
So i have a 1983 k10 that my washer motor doesnt work.
So, instead of replacing the whole unit with the same one (wipers also have started stopping when i turned the switch off, not completing their path first).
So, is there a switch i can wire in with a motor to have intermittent wipers? Thanks!
So you have a faulty washer pump and you would like intermittent wipers too, right?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
When my wipers wouldn't go intermittent, it ended up being a bad motor assembly. I would think that in order to have intermittent wipers, it would require the electronic control module to be wired into the system.
Joglz
