intermittent wiper questions
78C10BigTen
pennsylvannia
C10 BIG TEN
My 78 has factory intermittent wipers, can anyone tell me the pattern of how the switch works? And can someone tell me where the pulse board is located?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
That's aftermarket. I don't think they got intermittent wipers until they truely got square...
78C10BigTen
pennsylvannia
C10 BIG TEN
Im not sure because i can buy that switch at autozone... but like in the junkyard ive never seen one
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
It's a common upgrade from way back unless someone broke the original thingy off and jammed that knob in there.
78C10BigTen
pennsylvannia
C10 BIG TEN
The knob turns and if u push it they come one about 3 wipes
78C10BigTen
pennsylvannia
C10 BIG TEN
But i cant seem to make the timed intermittent part work
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
It goes on click to the left from off and about 3 clicks right from off
Take a peak behind the dash it is probably integrated into the switch. What you don't like living in Seattle? This 3 days of rain **** is pissing me off.
78C10BigTen
pennsylvannia
C10 BIG TEN
So
Someone told me its the pulse module under the hood, idk where it is plus the washer function dont spray.
Moderator
Ok...
It's factory
If there's no delay, it could be a faulty switch or module
The module is under the driver side of the dash
Slide left for wipe
Push for wash
1 notch right for delay
Rotate knob for amount of delay
2 notches right for low
3 notches right for high
78C10BigTen
pennsylvannia
C10 BIG TEN
Ok...
It's factory
Slide left for wipe
Push for wash
Thanks for the help i appreciate it. I figured rotate was amount of delay. I wasnt sure why it would have a slide left if it has high and low.
Moderator
It's supposed to be spring loaded, so when you bump it left, it returns to off on its own.
dudleyrushmore
