Interesting electrical question
87silveradok20
Ohio
Levi
Silverado k20
So I put 2015 style tow mirrors on my truck (the point of this thread is not to hate on them. I like them and if you don't it won't change my opinion). They have a courtesy light that shines backwards on them and I want to wire it in to work with the dome light. I wired up everything in the doors, put the door panels back on, and went to wire them in to the dome lights and realized that they are negative switched and I wired the lights on the mirror to be positive switched. I don't want to pull the doors back apart and run a power wire through the cab to the doors. So my question is is there some relay or something that will work to "convert" negative to positive. I know there's not a one wire in one wire out option but is there something that will work? Thanks in advance.
Ps. I attached a picture of the mirrors just for you guys who hate them
notime2d8
Alabama
Ken
K5 Blazer
I wanted to do this but didn't want to lose my vents. For the wiring.....the lights need a power and ground to work. So if you have constant power to the lights, you just need to wire the light ground to the door pin ground. Or just tap into the power and ground from the dome light - I've added extra lights this way, tapping into the light under the dash.
Sent from my SM-G900T using Tapatalk
87silveradok20
Ohio
Levi
Silverado k20
But the issue is that I have the mirrors set up to need a power to the lights to turn them on and off and the light under the dash in which I want to tap the power for has a ground to turn it on and off.
notime2d8
Alabama
Ken
K5 Blazer
Well....add a relay. Have the dome light ground switch on the relay and send power to the lights.
87silveradok20
Ohio
Levi
Silverado k20
Ok so I don't need a special relay to do this?
notime2d8
Alabama
Ken
K5 Blazer
Nope, a standard 4 pin relay. In the image, you can tie the 86 & 30 both to power, 87 to the mirrors, and 85 to the dome ground.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ok this is what I would do. Get a relay and use the ground to trigger on and off. 30 battery 87 to light. 86 jumped to terminal 30 and 85 to door striker switch
87silveradok20
Ohio
Levi
Silverado k20
Alrighty thank you guys that should get me what I need
