Intake Manifold Bolt Issue
firebane
Calgary, AB
Curtis
$100 later I own a Edelbrock 2101 intake now.
MadOgre
NA
NA
NA
NA
NA
Is it shiny ?
They are good intakes but be sure and use the felpro 1256 gaskets with the built in restrictors
MadOgre
NA
NA
NA
NA
NA
Not as shiny as I'd like but I'll clean it up and make it look good. Saved me $80 as they are $183 new where I live.
really, Wow. Im not sure what to use to clean those with. I would thinki Brake clean would be the safest bet. I know parts cleaner will turn them brown.
firebane
Calgary, AB
Curtis
I just wire brush them down and blow them off then spray gray enamel paint. I'll show pics.
MadOgre
NA
NA
NA
NA
NA
You could use that aluminum caliper paint. I sprayed my exhaust manifolds with that and its still on there a few years later.
firebane
Calgary, AB
Curtis
I've had good luck with appliance enamel in the cans.
MadOgre
NA
NA
NA
NA
NA
Ya that's pretty tuff stuff
Boone83K10
Boone, NC
Benjamin
make sure you start with the inner bolts first and tighten in a criss cross pattern. don't start with the outer bolts.
350runner
tx
Ceasar
Boone83K10
Boone, NC
Benjamin
hmm I have never seen a pattern like that before...
I have always done
12 8 1 2 5 9
11 7 4 3 6 10
might explain my oil leak coming down over fuel pump from intake....
Boone83K10
Boone, NC
Benjamin
ha just looked up instructions for my 2101... your pattern is correct... welp going to go buy some new gaskets and redo mine I guess.
350runner
tx
Ceasar
That's the GM intake torque sequence.
350runner
tx
Ceasar
It might just be the rtv didn't take to the intake or block. Or lil positive pressure(see pcv)
350runner
tx
Ceasar
In increments. 10ft/lbs, 15ft/lbs, and last 25ft/lbs
Garcjay
