installing aftermarket radio
86chevyk20
Buffalo
Liam
Hey guys i have a 200 w radio head that i bought from pepboys a few years ago and i barly used it so its like new.
My question i am looking for very detailed instructions on how to cut the dash for the radio and how to securee it to the dash.
I'm so nervous to cut into my dash so lots and lots of pics and very detiaeld instructions would be great.
and a wiring diagram too please!!!
Liam
X-cabsquarebody
Western NC
Billy
C10, C10 ,K30 , 3500
305 TPI, 454, 8.1
I wanted to see my radio, so I mounted it a little higher.
Swims350
Logan WV
none
usually you take the small cage/ring thing that comes with it, use it as a template to mark the plastic and the metal, cut them out, dremel or cut off tool, jigsaw whatever, even snips on the metal part.
you can cut and fold the dash back or completel cut it off.
trim the plastic, insert the cage into the plastic, bend some of the tabs down to hold it in place, or wait until it's sinatlled then bend tabs down, that makes it harder to remove later though, if you'd ever need to, you'd have to get in and bend the tabs to remove the plastic.
now for the wiring, best thing is to look online and find a wiring diagram with color codes, I forget them right off, you'll need a switch hot, constant hot, and ground, ground can be anywhere on the metal dash, or elsewhere, or find a factory ground, hots can be from factory or fro fuse box or directly to a junction block or battery for constant hot only.
then you need speaker wires, most only have the center speaker which means it only wires to one side which is kinda weird, I usually add other speakers, and wire them instead.
lmc has a dual speaker center now.
chengny
I just did this recently modifying the plastic bezel wasn't too bad. But, enlarging the actual steel dash behind it and fabricating a support bracket was tough, much more labor intensive.
The trim ring on the head unit is the limiting dimension - it just barely fits in the recessed area. You need to get the lower right hand corner as tight to the bezel border as possible. When you get it positioned scribe the inside of the opening. You only want the opening to be as big as the actual head unit - the sleeve goes behind the bezel and gets bracketed to the dash frame.
On the bezel, I drilled the 4 corners and used a jig saw with a metal cutting blade to make the rough opening. Dial it in with a lot of filing.
The steel dash opening needs to be enlarged as well. I used an air powered high speed cut-off tool. Don't completely detach the pieces you cut out. Leave the bottom connected and bend it back in towards the fire wall - it helps support the head unit sleeve.
Here are some images of how close the fit is:
7d7c10
Gallatin, Tn
Tim
LT1 350
I ordered a Metra 87-99-3052 installation kit off Ebay for mine. Very simple to install with this kit.
82SquareBurb
