Install door glass in sash
DGDamato
Charlotte, NC
Dominic
K5 Blazer
Last summer I removed my power windows and converted them to manual (and replaced all the rubbers while I was at it). I ran into an issue with the door channel's weld popping loose - I've fixed that with a rivet but with my new rubbers, the glass pulled out of the sash when I rolled the window down. Any of you know a better way to seat the glass in the sash instead of using the thin rubber piece that forms a u-channel? Hate to say that the seal is too tight (insert obvious comments here...) I've looked online and can't find any videos or how-to's on this - there are some but they don't cover the glass/sash install. Maybe a Urethane Adhesive? I am concerned that if I glue it in, I don't have the right spacing left and right.
Also, It was a pain to get the rollers into the sash with the rubbers and vent window in. I see some folks take out the vent window to re-install the glass...is this what I should do once I set the glass so I can install the glass and sash in one piece?
I have no AC and driving around with the door panel off isn't something I want to do for too long. Thanks in advance for any tips in this 90+ heat!
FireTruck1984
Michigan
1984 and 1984
LMC Truck and Kevin Tetz have a fairly informative video on YouTube showing this install.
3M Window Weld
If you take out the vent window first, it’s relatively easy to slide the door glass up and out. However, you have to to slide the glass back and forth to get it to to release from the channel on the regulator, and that takes some finesse.
The channel on the regulator has a short cutout on the side, and you
slide the glass forward until the roller mounted on the glass lines up with the slot so you can pop it out or into the track. If you don’t pull the vent window you can’t slide the glass forward enough to get the roller out through the cutout.
I had more trouble getting the window back in because once you line it up you have no leverage to push the roller outward and back into the track. That’s where the finesse comes in.
kurt54
