Inoperative Gauges
Tractorman
New Jersey
C30 Crewcab
7.4l
All gauges in instrument cluster with the exception of speedometer and fuel are inoperative.
Has anyone run across a common problem for this?
Trucksareforwork
Spartanburg SC
Geoff
If you mean suddenly they are inoperative, then no. I don’t remember if there is a common fuse or anything.
But, when I got my ‘85 it’s oil pressure, temp, and voltage gauges did not work and I took the cluster apart, cleaned them up, and tested them. Two were fine and the problem was downstream (new oil pressure sender, new temp sender). The voltage gauge needed a new resistor which was a 10 cent part that I wired up behind the gauge in 2 minutes.
So, if you are talking about repairing gauges that have quit one by one over time, then it’s trial and error and get out your multimeter and a 12v source.
If all of the sudden then I don’t know.
Tractorman
New Jersey
C30 Crewcab
7.4l
Thank you was not all of a sudden so I will give your approach a try.
Snoots
Roger
Jimmy Sierra
350 w/203
Check your ground buss that's just behind the parking brake on the upper part of the kickpanel.
Finkaire
Finkaire
California
Loren
Silverado c10
There’s a plastic circuit board that contains the ground. I used a paper clip to fix, years later I bought a board on line.
wilson79
