Im stumpped
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Doh!
Didnt know they wouldnt show up nobody mentioned it before. I will grab them and post them up when I get back to the house.
Jims86
Patterson,Ca
5.7 TBI
Ok so you was able to hear what happens when I try to full throttle the truck now keep in mind when I took that video the map sensor was unplugged so that I was able to idle the motor and I won't be able to run the test you have explained to me until Wednesday as I have school tomorrow. Also did you get my text message I sent to you Jim?
Yup, I got it.
One thing I have not asked, have you put a new fuel filter in the 87?
HR, seems like the problem he is having is not EGR or vac leak related, after a certain RPM, it would still rev higher than he is able to get it.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I have tested the EGR and replaced it and same with IAC and spark control module and the distributor as jim had said prior to the message I will be test the fuel system from my parts truck I have and I will also be replaceing my temp sensor as I noticed the other day that is it not working
You know for a fact the temp sensor is not working?? :eek:??? That's probably the problem right there buddy. That was going to be my next suggestion after the EGR and IAC. And forgimme if you had already said that was done, I skimmed the thread a bit. But, if you want to save some time testing all that other stuff and you KNOW for a fact the temp sensor needs replaced, then I'd do that first and it very well might fix your problem. And it's temp sensor, not temp sender to the guage right? Temp sensor WILL cause issues including hard start and driveability issues. That would be my next step right there.
How about codes?? I think Temp Sensor code is 15.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Idk if the code is there but I know the gauge does not read even when the truck has ran for an hour and I can tell the temp is at normal with the use of a thermometer water temp is at 190 to 210
So you're referring to temp sender for the guage. Not temp sensor for the ECM. The temp sensor can cause issues too.
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
not to jack the tread but, my 79 its only a temp sender correct? cus it always read's like 1/6 of the guage at oporating temp.
Jims86
Patterson,Ca
5.7 TBI
Yes, yours might be in the manifold or thermostat housing...they call them switches in the parts books.
Where are the temp sensor and temp sensor located at?
Paul, your sensor for the computer is in the manifold, to the left(looking in) of the thermostat.
You gauge switch or sender is in the drivers side head, between 1 and 3
Jims86
Patterson,Ca
5.7 TBI
Love the wheels on Brownie, BTW!
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ok so its a 2 prong plug by the thermostat that goes to ecm and the on on the driver side of the cylinder head is for the gauge. And is a single wire correct
Kapdin
North Dakota
Lance
thought it was this.
Jims86
Patterson,Ca
5.7 TBI
Thats it....most of the ones I have seen from the carb days were in the intake or water neck.
Jims86
Patterson,Ca
5.7 TBI
El Greengo
