Idiot I am no trans fluid
86suburbanNJ609
South Jersey
Aaron
Suburban
The truck shifted fine until OD and went in short and fast red flag immediately. At the next stop sign pulling away shifts into second and poof no more third gear no clunking noise of any kind manually shifts but no more 3rd or 4th.
So I limped home and checked fluid and like a punch to the gut is was bone dry.
Im on my way to napa for fluid now
Might want to take a look for leaks. That extension housing seal that goes around the slip yoke will randomly start and stop leaking on mine. I’ve also had them leak at the TV cable grommet and dipstick grommet. They can leak at shifter seal, too. I hope the transmission will prevail after this. You’ve got a NAPA open after nine o’clock EST? Impressive. I live a few minutes from the warehouse/parts counter, and I think they call it at eight.
84 Shorty
Grovetown, GA
Andrew
Truck shouldn’t even move out of park if it’s that low on tranny fluid I thought. That’s some severe leak you got there. Hopefully you didn’t cause any damage to the transmission.
700r4's have also been known to puke out the front seal too.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Mine does this lol, ripping my trans out sometime in the next couple weeks
86suburbanNJ609
South Jersey
Aaron
Suburban
I'm on the market for a th400 truck has a 350 373 gears and 208 t-case
Should I post on the wanted section?
BradBow
