I need my Quadrajet rebuilt. Any specialist Here??
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
I have seen the Teflon bushings after some use, and they shred up and come apart. Not as effective as pressed in bushings.
Nasty-lsx it's not that hard to pull one apart, clean it and put it together. The key is the calibrations and replacing the parts that most people don't do, like the primary shaft bushings and the secondary air valve cam and spring. For these old carbs, an over the counter kit just doesn't have what is needed anymore, and the quality of what is in there isn't good.
350runner
tx
Ceasar
Let's see how they hold up to the test of time.:) I don't think they would hood up better then metal.
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
I should have taken pictures, but I didn't. I don't know how long they were in use, but they were no longer effective. I build about 150 Quadrajets a year, so I see lots of interesting things.
350runner
tx
Ceasar
Yea I bet the engine heat and throttle shaft rotation put a beating on the Teflon
one4fun
Portland, oregon
chris
I will be buying a qjet from Mark after the holidays. Recommended by many others on the forum. ;)
MrMarty51
Eastern Montana
Martin
Too bad someone would`nt make a screw in style of a bushing, that would use the same unworn portion of the shaft/base-plate.
Drill, tap and screw them in, a mild locktite to hold them and a slice on each side of the bushing, so they could be screwed out when worn and a new one installed, along with a new throttle shaft.
I think that using that wider portion of the base plate and shaft that, those bushings and shaft would last for a very long time.
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Prob not. If i need to redo them i will use brass, or i have a whole sheet of the stuff. Its not like i put even 5k on a year.
350runner
tx
Ceasar
Good deal bud. Glad to see someone finding an alternative method to a problem :)
SkinnyG
Canada, eh?!
G
C10 Silverado
350/TH350
I made a tool to bore out the worn bushings, and then inserted bushings I found at my local auto parts store.
I also bought and followed Cliff Ruggles' book on Rochesters - a great book!
MadOgre
NA
NA
NA
NA
NA
Yes now that is the correct tool for doing bushings. The drill bit cliff sells is just a disaster waiting to happen.
Did you turn it on a lathe?
350runner
tx
Ceasar
Dude cliffs bit is self aligning.... it worked perfectly when I used it. Coulda done it with my eyes closed...
MadOgre
NA
NA
NA
NA
NA
Yep until you gouge out the center bore on the throttle plate and your throttle shaft binds. Then your only option is a new throttle plate.
The correct way is with a back cutting reamer bit.
350runner
tx
Ceasar
SMH....
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Mark, can i call you? thanks. :cheers:
bvandrey
