I need my Quadrajet rebuilt. Any specialist Here??
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I pretty sure i can do it myself. But would rather have it done correctly the first time. :cheers:
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
Good morning. I am pretty new around this forum, but have done some work for several members. Check out my website at www.quadrajetpower.com to see the work I do. Much more than just a kit, it will be better than new and built for your engine set up specifically.
Let me know if you have any questions.
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
I did mine recently. Never done one before, it turned out well. I bought a kit from napa and a gasket set from quadrant parts.com.
I also bought some teflon to bush the main throttle shaft
Runs way better than before.
Sent from my Nexus 7 using Tapatalk
Skweegle89
Oklahoma
^ what he said.
Boone83K10
Boone, NC
Benjamin
Anybody want to send me a quadrajet?
Boone83K10
Boone, NC
Benjamin
Holley 4175. I like it but mpg are bad and it is starting to leak down on #2 cylinder and that is only plug that is carbon fouled. Plus it's leaking fuel at throttle shaft.
350runner
tx
Ceasar
Are you using a square bore intake?
Boone83K10
Boone, NC
Benjamin
No, Edelbrock 2101. Really I just wanted to tinker with a Qjet, anyways want to learn. Rebuilt a one barrel carb on family's 75 Plymouth Scamp slant 6.
350runner
tx
Ceasar
Ah good deal your good to go then. A qjet is easy once you know what how to properly set it.
MadOgre
NA
NA
NA
NA
NA
What did you use for the Teflon bushings ?
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
You guys make it sound so easy!
MadOgre
NA
NA
NA
NA
NA
Best advice would be for a first timer to get a spare junk yard one and disassemble it first so you can see and figure out how it comes apart and works
350runner
tx
Ceasar
How did you use that?
Brianall
