I’m so smart
WFO
Texas Panhandle
These any help?
Those are almost too pretty to cover up and use.
Disco
Texarkana, TX
Big 10
I didn't read everything so this may be covered but here's the acronym BOB big on back. The rear shoe is the long shoe
That actually helps a lot! Thanks! I use mnemonics like that all the time (over a decade wrenching and I still tell myself "righty-tighty").
These drums are a bigger PITA than I remember and than I have ever done. how do you stretch a spring you can't even flex?! You need to be an octopus to do the job, as everything keeps trying to fall off while I'm trying to install springs.
I am so putting a disc brake conversion on the future to-do list. I should be able to scrape together enough by the time these brakes need replaced...
Disco
Texarkana, TX
Big 10
Btw, y’all, I have looked. My Big10 does NOT have adjuster holes in either the backing plates or the drums, nor does it have un-punched holes. Solid plate, solid drum.
ali_c20
Austria
Alexander
C20, K5
Earlier models don't have the adjuster hole, my 79k5 no hole, a friends 77c10 no hole, his 86 c10 has the hole.
I drilled holes in my backing plates, tapped them and put short bolts in to keep the dirt out.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Aftermarket drums dont seem to come with the knock out plugs, so it could be that is the reason for your above examples.
The drilled hole and bolts strikes me as a stroke of genius - well played!
:waytogo:
The Right side of Washington
Overkill. Everything was blasted and then replated. The springs were repainted to match the factory colors. I'm 100% certifiable. lmao
Dang dude.
Do you have clear brake drums to show off that setup?
Disco
Texarkana, TX
Big 10
No you didn't. No pics, it didn't happen
Believe me. It happened. There’s no pics because I was QUITE done with these drums.
Disc conversion kit on the list of future things to do…
Disco
Texarkana, TX
Big 10
It took long enough that my brand new wheel cylinders are rusty. Lol
Soundmound
Aiken, SC
Dave
Scottsdale
Don't do it, it's a trap! LOL. I was eager to swap to rear disc also, but having seen enough negative threads here on the topic, I am pulling an about face.
Carb'ed Vortec 350
It's a rule, I didn't write it...lol...
Take a pic of some rear tire skid marks showing they work...lol...
Matt Lutz
Bastrop
Lutz
250 4.1L
Thanks for the great pics! I was trying to put the adjuster bolt mech in the wrong spot and of course I was having issues! Instead of putting it on the vertical piece I was trying to put it on the horizontal piece. I have great pictures of the top of the system from before I disassembled it but did not get a picture of the bottom. I actually woke up wondering "How the hell does that adjuster stay on?" Now I know!
samelthecamel19
