Hydro boost parts
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I need a brake pedal for a hydro boost square and also the mounting plate for the booster. I have a hydro boost unit already.
Moderator Administrator
Is the pedal really different? I converted an 80 from Hydro Boost to Vac Boost. Bolted right in, not problems. :shrug:
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Everyone says about the distance from the mounting bolt to the pin the rod attaches to is different. Plus I need to be able to get a brake switch from a 1994 truck on the pin also
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
It is. Look at the distance from the pin to the bend above it. The hb pedal is on the bottom.
You can see the need for a different pedal by looking at the push rods of the two. I remember reading that some guys get around switching pedals by cutting the push rod on the hb in half and threading the cut ends, then reattaching them with a coupling nut so the rod length is adjustable.
I also found out the brake switch activator (which is bolted to the pedal) is longer on a hb. I forgot to get the correct one from the junk yard when I picked up the pedal so I cut and welded in a short piece of steel so it would bolt on and reach the switches. I think I could have drilled a new mounting hole in the pedal instead of the welding mod but I didn't want to remove the pedal again.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Well I got everything today at a junk yard BUT the plate the hydro boost mounts too. I couldn't get the damn nut off the junk one.
Brianall
