Howdy from Nebraska
animal
Moderator
Lee
c10 silverado
350ish
:welcome:
1973c10
Don
Welcome aboard :boti:
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
Welcome from LA (Lower Arkansas).
Gabbs
Omaha, NE
Gabrielle
Alright fellas...I gotta pick your brains.
Tonight we replaced the capped off brake line, bled all the brakes about 3 times and had a pretty good pedal. No leaks. Drove it around the block and it was good. Then drove it about 3 miles to my mom's and when I came back to the truck...no pressure. Babied it home, pressure sometimes built up, but then I lost it. Seemed like the rear passenger was the only one working again, just like on day 1.
Master cylinder? Brake booster? Replace both? Good brands?
And THANK YOU ALL FOR THE WARM WELCOME!!
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I trust bendix and raybestos for brake parts, but others may be good as well.
I’m assuming with a 3/4 ton gas truck you have a vacuum booster and you can pressure test that. Get a new master cylinder and bench bleed it first. Prop valve may need centering if you suddenly lost one of the circuits.
K201979
Winona, missouri
Hippie
350ci
Welcome from southern Missouri. I would try bleeding again before i thru any more parts at it. Some times it can be a b*tch to get all the air out. The id say maybe booster/master.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
I agree with this.
Also check for any places that might be letting air in. Maybe there's a reason someone tried capping off one of the lines rather than just fixing it
RecklessWOT
New Hampshire
Kevin
Oh, and welcome to the site by the way!
ALL-OF-IT
Nebraska
Adam
323.425844 cubic inches
Welcome, from NE as well, Ill bet we have mutual friends. Lived in Lincoln for a while and did a lot of racing in Omaha/Lincoln for some years. know a lot of "car ppl" from that area
Carb'ed Vortec 350
Welcome! I'd also go with bleeding the brakes again before throwing parts at it. But most likely you'll be throwing brake parts at it.
Craig 85
Nashville, TN
454/TH-400/NP205
Also, any recommendations on tires? The rears at 16.5" and I can't find them anywhere online. The fronts are nearly new. Wouldn't mind getting new wheels.
Firestone Transforce H/T is about the only 16.5" tire out there. I'd probably switch over to 16 or 17" wheels.
78C10BigTen
pennsylvannia
C10 BIG TEN
Ive shred many of those... they are a heavy tire
samelthecamel19
