How does hood to cowl seal attach?
MisterB
Northwest
AJ
GMC K2500 4X4
Mine is missing, so I can't tell how it connects. I'm guessing it attaches through the holes all along the edge in the pic of my truck?
The part from LMC shows that there are these things that poke down, so I wasn't sure if that's how it connects. They don't seem to sell any other hardware that would connect it. I checked Brothers for reference, and they sell these square brackets with screws.
Any light you can shine on it would be helpful. I've ordered the LMC seal, but it hasn't arrived yet.
Sent from my SM-N975U1 using Tapatalk
Big Chip
Michigan
Kevin
C35
There's little push in clips attached to the seal that you just push into the holes in front of the cowl screen.
The new one I put on had the same clips as the original I removed.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
These little dealies. Lever style likely.
I'd pop one out to show if I felt I could do it without breaking it. Looks like this on an 84 where it is on the underside of a hood.
MisterB
Northwest
AJ
GMC K2500 4X4
Thanks fellas. I'll just wait for it to show up, and it sounds like it'll have those push clips. If not, I have some left over from the old screen I can use
Big Chip
Michigan
Kevin
C35
They’re T shaped, not round.
FireTruck1984
Michigan
Ted
1984 and 1984
Starting in ‘81 the seal attaches to the hood
I ordered the one from LMC a few weeks ago and it came with the clips in it. I also have an 80, it just clipped right into the holes, perfect fit. Took maybe 5 minutes to install, 3 of which involved acquiring and opening my beer.
MisterB
Northwest
AJ
GMC K2500 4X4
Sweet. Sometimes those kind of jobs are nice to have. They off set the more tedious and frustrating jobs
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
3 minutes?
Were your hands tied behind your back or something? :33:
3 minutes?
He keeps his beer in the cold, nice, fridge. THats downstairs and like half a block from the shed!
wixthedog
Magnolia, Texas
When I ordered a new seal I did not read that it came with new fasteners so I ordered those, they may have been a couple of dollars. I left the seal in the hot Texas sun for an hour or so and it made install even easier, about 1 minute compared to 2...
MikeB
Replaced the one on my 82's hood last year. Many of the clips were so hard to push in that I had to remove the hood. However, it was super easy to do with the hood on its back.
MisterB
Northwest
AJ
GMC K2500 4X4
I got mine installed. I figured out a little trick. I used the side of a flathead screwdriver to press on each plastic button to get them to push in.
80BrownK10
Greenwood, SC
Nate
My cowl seal is all smashed and just randomly laying in there I think. Maybe I will replace it. Keep that engine heat out of the cowl and spilling as bad back into the cab I guess
