how do you remove a broken zerk??
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
so i was workin on the add a leaf setup, bending the bars that hold the leaves in place... and i accidentally hit a zerk. so any of yall know how to remove a broken one?
nvrenuf
Mobile, Al.
Zerks are hollow so no drilling, just stick an e-z out in it and turn it out.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
i tried... it would just slip. i even whacked it with a hammer to jam it in but still wouldnt work...
Moderator Administrator
What's the zerk go to? If it's really that big of an issue that you can't get it, you can needle grease it, then put a dab of RTV over it and call it good. This all depends what it is though. I sure wouldn't do that to a U joint.
Moderator
Use a reverse drill bit that is significantly larger than the hole in the zerk.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
It's on what I believe is the drag link.
WB chengy, didn't you see you on for a couple days. ChevyChase signed up here yesterday.
chengny
Been on Saab repair duty - and the truck is away from me (in the body shop).
I tend to visit the forums associated with the current jobs.
You know how it is; good, well-researched answers can take some serious time before posting.
DrtboyAviator
