How do I fix this rust.
86chevyk20
Buffalo
Liam
fire wall rust. Ughhhh best way to fix. And the rear support under the back of the cab has a few bad spots. Ideas. I'm keeping this cab too btw.
86chevyk20
Buffalo
Liam
More cab
86chevyk20
Buffalo
Liam
Support
86chevyk20
Buffalo
Liam
More
firebane
Calgary, AB
Curtis
If your keeping the cab its going to have to come off to do the required repairs. Only way to do it properly.
MadOgre
NA
NA
NA
NA
NA
Yep and get a welder
chengny
Need a cab? I have one that will be available soon. It does need a little work:
Driver's floor is completely shot - like a Fred Flintsone floor. It needs rockers (inner and outer - both sides), cab corners, floor supports and channels.
Comes with no doors, no wiring harness, no glass, HVAC system or any other interior parts.
It does have roof markers - but I am keeping those. So unfortunately, there will be 5 holes in the roof.
It has had an AC conversion done to it. As a result, there is a homemade hole in the RH side of the firewall. That's not a problem though, the hole is covered up with a piece of sheet metal. There is also a pretty big dent on the back wall of the cab behind the driver.
The paint is blue and faded (but not everywhere - only in the areas that get exposed to sunlight)
But other than those few things, it's still a pretty sweet deal.
MannyDantyla
Lawrence, KS
Danny
sbc350/sm365/np205
Is there any way to slow down the rust?
Georgeb
Wisconsin
George
K10 Burb Z71
I have had success with boiled linseed oil in the past. I would thin it just enough to spray it through an old siphon gun. Did it every fall. With plenty of washes after trip in the salt I really slowed the rust down.
MadOgre
NA
NA
NA
NA
NA
Take a wire wheel to it and brush/spray on some rust mort or any other high quality rust converter then prime with self etching primer.
Rust if not fully stopped returns in very short order.
How ever POR 15 claims that you can paint it right over top of rust but I dunno how long lasting that is
Snips71
