Hood insulation pad
adamj
Colorado
Terrence
V20 Suburban
5.7L TBI
I'd like to install one of these to cut down on engine noise.
Did squarebodies ever come with these from the factory?
Is someone still making them new? Or is there an aftermarket solution that works better?
I see some holes in the inner hood panel, looks like it could accommodate one.
Here's what my hood looks like:
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I took mine off, after years of getting sprayed with oil and other fluids, it becomes a fire hazzard. Eventually they all get loaded up with debris and fall down onto the motor. If you're concerned with motor noise, install some sound deadening like dynomat or something similar. The factory mat imo isn't worth the money and it doesn't quiet down the underhood noise/heat transfer adequately.
adamj
Colorado
Terrence
V20 Suburban
5.7L TBI
Thanks for the tip - I am looking into that, and I think it's a better option and probably does better for noise than a factory-like pad.
MikeB
Make sure whatever you use is designed to handle engine compartment heat. I suspect most of the interior sound deadeners will fall off. DEI (Design Engineering) makes good stuff, but they are expensive. I think DynaMat also has something specifically for under hoods.
adamj
Colorado
Terrence
V20 Suburban
5.7L TBI
I think I'm going with the dynamat hoodliner. It's designed for under hood and resists oil and can withstand the heat.
thomasj
Richmond
Thomas
Sierra 2500HD
Yea, the dynamat sounds like a good option!
Todd Lemon
