Holes in Firewall
bigge31566
GA
Ervin
I have three holes in firewall next to wiper motor and brake booster, trying to figure what goes thru them, I know the top one to the left is for the speedometer cable, but there are two other that are stacked on top of each other, any ideas, Drawing need to rotate to right sorry
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Wiring harness is one of the other two holes. The third....doesn't look like factory.
bigge31566
GA
Ervin
Im installing a wiring kit and will be using the holes if they arent percifically for anything
chengny
Here is yours side by side with a stock firewall - note the sealant over the punchouts on mine:
I am going to say speedometer cable, cruise control vacuum line to the brake override switch and...that's all I got.
MadOgre
NA
NA
NA
NA
NA
I know my diesel has more grommets then the gas
bigge31566
GA
Ervin
thanks ill probably use both of those to run new systm since I dont have cruise
Moderator Administrator
How have you flew under the radar and gotten by without posting pics of your truck Ervin? :happy175: Seems you just post up in a tech section and act as if you've been here forever. No Intro thread, no build thread... :lol: Now you're caught !!! Let's see what you're working on. I see lots of threads started, so you're obviously working on it. How about a build thread in the under construction section? :shrug:
ScottyB
Whatcom County, Washington
Scott
phantom
2 squirrels
Mods were slacking and so bad habits were encouraged. :D
MadOgre
NA
NA
NA
NA
NA
My 6.2 diesel has the 3 holes in the firewall in the exact same location as yours. Don't know if it has to do with it being a diesel or if its because it came with the full trim level ?
bajadiver
