High IdLE???
I replaced all the vacuum lines I could find
Anything hidden I may have missed??
Vacuum at the bottle if the throttle body??
How can check/adjust?
With everything connected and the air filter installed spray around the entire intake manifold with starting fluid and see if it revs up.
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
I have a throttle position sensor on its way
In hopes it's that
If y'all have any other suggestions I would appreciate it.
I will say
That at some point the stock intake was removed and has a 15" air filter
Chaz
USA
Chaz
V1500 Suburban
350 tbi/th400/np241c
So what kind of intake is on it now? Stock throttle body correct? Could be intake manifold gasket leak if someone swapped out the manifold.
Boone83K10
Boone, NC
Benjamin
Could it be the timing, way advanced?
Boone83K10
Boone, NC
Benjamin
What else did you try? Did you mess with the timing at all?
v2500burb
Jay
v2500
350ci
Haven't messed with timing
Don't have a gun
I've replaced all vacuum lines I could find (runs better)
Cleaned the IAC
Checked for vacuum leaks
350runner
tx
Ceasar
Did you ever install the TPS
Chaz
USA
Chaz
V1500 Suburban
I would check the timing,,,Theres a wire plug in you have to disconnect before you set the timing at 0deg TDC,,,,Its worth it to check the timing,,,these GM TBI motors are a pain in the ass to diagnose but when theyre running good they really do run good. High idle could be your timing is too far advanced.
But most common cause is vac leak, aftermarket parts like coil, pcv valve, whatever can cause big problems.
I had an msd coil on mine and it fried the rotor inside the cap, was a new cap and rotor, I had to take it to a mechanic to have him go through every component until he checked the rotor and found it was cooked inside. You couldn't tell it was bad by looking at it. Replaced it and the coil and its been running good since.
v2500burb
Jay
v2500
350ci
I put a new IAC in yesterday and it seems to have solved the problem
Instead of idle ing at 1000 -1100
It idles at 600-700
It idles at 600-700
Let us know if that stops the surging idle issue too, thanks.
mick84
