80BrownK10
- Oct 22, 2019
- Greenwood, SC
- Nate
- K10
I rolled out my rear main bearing but can't seem to get the new one in. It hits the block. There .010 bearings like the crank was stamped. I don't have a mic but used my calipers to measure the leading edge of the bearing and it measures the same as the old.
I have all main caps loose what are some tricks here.
Only think that comes to mind is to taper that edge against the block so it will start but something tells me that's probably not a good idea.
