help!! Swapping inner door parts, regulator, glass, rubber etc.
Nick.koehler6
IL
Nick
350 5.7L
how do you replace the door window and all the inner door parts. it has crank windows. I can't seem to figure it out. I'm swapping my doors parts into a new door shell
chengny
Here's how to get the windows out for a start:
Remove the window crank, arm rest, inner handle cup, lock button, etc.
Remove the door panel.
Remove the vent window assembly (incl the frame) as per the procedure above. It takes a little finesse - but after a couple of twists and turns you will get it out.
Then disengage the sash from the regulator rollers by raising/lowering it until the rollers line up with the slots in the sash. Pull the sash out through the top.
After they are out of the way, you should be able to figure out how to pull the regulator.
The locks and handles can be tricky. Come back when you get to those.
Welcome to GMSB Nick. Looks like Jerry as you hooked up with the info you need. Feel free to respond if you need further help and do let us know how you're coming along with it. Some pics would be great too.
Just an FYI, I've edited the thread title. We don't like generic thread titles and they are often overlooked. Please be sure to put something related to the issue in the title. It helps those doing searches for related topic info and also gets you more responses.
bluex
Spartanburg SC
C15
@chengny got anything like that for rear doors? Just ordered the glass run for mine...
jake26104
