Help on these please.
Jason Reed
Bakersfield, Ca
Jason
GMC K-15
Im restoring my 1974 C-10 Stepside and these came out of my corners up under the dash. They appear to be rubber seals or something? What are they and where can I get them?
Thanks
-Jason
They were under the dash? Those are the fillers that go between the cab and the fender. They have a few screws with large washers that attach them to the cab.
Jason Reed
Bakersfield, Ca
Jason
GMC K-15
That’s them. Where can I get these? I looked on LMC & Brothers. Didn’t see them.
Jason-
They may not be reproduced yet. I have never looked for new ones, I actually leave them off. I think they promote the buildup of leaves and such, giving the fenders a better chance of rusting out.
Cemack
Alberta Canada
K15
Yes they screw into the cab and form a seal between your fender/in front of the door. When I removed mine while restoring my truck i found they caused a lot of rust,especially at the top. I had to weld a patch in because they caused so much rust. I would like to leave them out as well, but think that may cause a lot of wind noise inside the cab
twzorek
