Heater blowing a small amount of air
Eighty5ov
Canada
Ov
c15
My heater barely blows air out, any suggestions on a fix or what I should do? My plans are to hook it up to a battery to see if the motor blows on a full send. Then don’t know where to go from there. Thanks any help is appreciated
WP29P4A
Nevada
Sierra Classic V1500
Did you check to see if the vacuum line that controls the vent position is connected? Can you hear the door close when you change from vent to heat? Is the air coming out in one area? under dash, defogger vents, dash vents, or all three places? Does the fan switch change the noise level of air flow?
Eighty5ov
Canada
Ov
c15
I haven’t tried anything yet. But I will try these!
If you pull out the blower motor you might find that the squirrel cage is broken or has broken loose from the blower motor shaft. The squirrel cage is made out of plastic or nylon, so not real durable.
With no vacuum to the controls (broken line, etc.) I believe the system splits the air flow between the floor and the defroster, and there may be nothing coming out of the dash vents.
Eighty5ov
Canada
Ov
c15
So I did some diagnostic activities. I pulled the motor and hooked it straight to power source. Ran full send. The air will come out of all areas. I can hear the door close. And the fan switch doesn’t change anything. I think blower motor switch but I still have to see if any power is going to the resistor. Or any idea?
WP29P4A
Nevada
Most fans have a constant hot and the ground wire is the one that goes to the switch and has three different resistors on or in the switch to give it the 3 speeds, verify the constant power to the fan before looking for power on switch, should save time and confusion. Took me a while to figure out dome light and fan circuits that are constant power and use the ground to switch the device on and off.
Eighty5ov
Canada
Ov
c15
I will indeed try that. Thanks I will be back on here when I do it. Most likely tomorrow.
Check for power at the resistor block on the box in the engine compartment.
86 squared
