Heater blank cut file
Chuckyj95
NY
Chuck
Before I do a cardboard template does anyone have a cut file for the heater blank?
xm20k
Girard, Ohio
If you're talking about a block off plate just to cover the hole in the fire wall it's just a flat piece of sheet the squares are not that involved, you can even buy them for less than $30 not like the older trucks where they are more complicated and run $100-200.
They don't even need to be shaped like this they could just be a rectangle.
Shifted
