Headliner/interior trim
GMC_Nick
pittsburgh
Nick
350 sbc
Putting the plastic interior trim in my 85 Scottsdale. What size screws did they use and how would you guys go about putting it up? I don't have the holes in the cab for it so should I just put holes wherever the pieces line up?
FireTruck1984
Michigan
Ted
1984 and 1984
Easy, fit one piece at a time, tape the trim in place..pre drill one hole into the metal, anchor with one screw then proceed to drill the other holes while the trim is in the correct location. Use Stainless trim screws, if I remember mine were 3/4 and 1”
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Install the rear corners first, then the front pillars. Once those are positioned it's easier to install the metal strips. I did it on my '79' I don't recall the screw sizes though. I may have just bought the screw kit from LMC.
mick84
