Headlights?
Doubletop
Muncie, IN
Doug
87 GMC with the quad headlights. Driver's side top light goes out when brights activated. It works fine on low beam. I've replaced the light and verified it's the right bulb cause it's the same as on the passenger side. Any ideas?
Rickf
Grafton NH
1974, 1954 & a 1937
I thought some trucks w/4 headlights only allow high or low beam not both. I could be wrong, I'm old.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
That's only on the 89-91's. @Doubletop are you getting power at the connector?
Doubletop
Muncie, IN
Doug
The light is on with low power and only goes out when brights are turned on. So if I'm getting power with low beams wouldn't I still be getting power with high beams? Sorry, electrical work is far from my specialty.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
No the high beam circuit is a different circuit so there's an issue in that wiring. Low beams will be on low beam mode and high beam mode. while high beam lamps only come on while in high beam mode.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
There is a high beam switch on the left side of the column. I know we have the thread on it, but I found this one first on the internet. It will give you some info on where to look. It could also be the headlight switch. There are a variety of videos that explain how it works.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=30639.0
Doubletop
Muncie, IN
Doug
Thanks guys. Leaving town for the next week but I’ll try these suggestions when I get back.
Joe Smo
Toronto
Joe
Check your switch but I bet its a bad ground wire.
mick84
