Headers
hugedogleg
Stephenville, Texas
Austin
3/4 Ton 4x4
I am putting a '90 454 TBI in my 87 3/4 4x4. Does anybody know what headers will work. Thanks for any help.
nvrenuf
Mobile, Al.
Personal preference really but I know that Hedman and Sanderson both make headers specifically for square body 4wd's w/ big blocks. I have used both with no mods.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Whatever you choose, unless you get shorties, you will need to upgrade to a 3 wire heated o2 sensor from a 93-95 and it needs to read only from the drivers side cylinders.
Swims350
Logan WV
none
are you keeping it tbi?
basically headers need to match the vehicle the motor is in, and the block size, as in if it's big block 73-87 or small block, then if you keep tbi you need an o2 sensor in the headers, if not then basically bolt on and go.
hugedogleg
Stephenville, Texas
Austin
3/4 Ton 4x4
yes I plan on keeping it TBI. I am going to check on the hedman. Thanks guys. I didn't even think about the O2 sensor.
