Header/Front Drive Shaft Issue
Chipper2oo3
Alabama RTR!!!
Chip
Bought a set of summit full length headers and my front drive shaft is hitting my right side when I lock into 4wd or lock my hubs in. I pulled out my drive shaft and the joints feel fine and the slip yoke only has a small amount of slack. Anyone ran into this? Have the driveshaft fixed or take the headers back off? The grease fitting has already tore a hole in one of the tubes... Summit verified they were 2wd/4wd compatible.
Swims350
Logan WV
none
never seen it before we had dynomaz headers from a 76 2wd 3 spd on the column and put them on an 86 k10 with an auto and had no issues.
Your engine mounts may be in bad shape.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Yep you will have front driveshaft issues with long tube headers. It gets a little better with lift but there is still contact upon up travel of the passenger side.
The only clearance issue I've ever had was with the shackles, d-shaft was always fine. Never run those Summitt headers though.
Swims350
Logan WV
none
the summit headers are flowtechs we have the same set on dad's 84 and his 86 was stock with them dynomax ones then lifted and never an issue.
Hmm, I didn't know that. I had Flowtechs on the '77 Blazer that's stock height and they cleared everything just fine.
Swims350
Logan WV
none
yea our box even had the flowtech part number on it.
hootsmcgoots
Norton, VA
Jason
305/SM465
I have the flowtechs on an 86 4x4 4sp and haven't had any such issue..... x2 on motor mounts, or check end play on pinion and t/c yokes.
sever
