Head scratchinh situation
dusterdude
US
mark
gmc c15
Ok guys,i recently installed a small cap electronic distributor with an external coil.it seems im not getting spark but,my timing light flashes when i crank the engine.im at a loss here and by the way,this is on a carbureted truck.does anyone have any ideas?
mxer147
Colorado
Jack
k20
when in doubt, I pull a plug wire off, put a small screwdriver into the plug socket, lay it across the exhaust manifold, and look for spark. No spark, I meter for 12 volt power at the coil, then to the next component until I find the failure point. If spark, make sure number one lines up with the rotor and the firing order is correct.
Redfish
Prairieville, LA
Andrew
V1500
We can assume you stabbed the distributor correctly and that cylinder 1 is getting fire when it is supposed to? And that all the plug wires are re-oriented correctly?
It is possible that there is enough "spark" for your timing light to pick up but not enough spark to arc across the plugs and fire the engine.
dusterdude
US
mark
gmc c15
Redfish,that is a damn good question.ill check it out
dusterdude
US
mark
gmc c15
Back to this issue,i am getting 12.5 volts to the wire that plugs into the coil with key on but when i crank i only get about 10.5 volts on this wire.this seems to be recent phenomenon.does anyone where i should look for the drop?thanks
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
I would try running a ground wire from Dist hold down bolt to ext. coil 1st,, cheap n easy try
dusterdude
US
mark
gmc c15
Would i ground the coil end to the hold down bolt on the coil too?
Snoots
Roger
Jimmy Sierra
350 w/203
It sounds like your wire from the battery to the starter is 'sinking' more than it should. Possibly due to age. 10.5 volts shouldn't cause an ignition problem tho while cranking.
Rickf
Grafton NH
1974, 1954 & a 1937
You are having the same voltage drop issue that I have with my '74, however my truck started with a points distributor and the previous owner installed an HEI. To get mine to run I need it to get it spinning (key in start position) then let it go so it is in the run position. When I get around to it I'll eliminate the resistor wire, but for now this plus the extra pedal on the floor act as an anti-theft system.
What are the odds you have a resistor wire floating around?
How many small studs and/or wires are on your starter solenoid?
Turbo4whl
Downingtown, PA
Wayne
Jimmy
10.5 volts is all you will get at the coil when starter is cranking. The HEI will start with that voltage. What does your new distributor require? Should it have a capacitor wired in to maintain the voltage when cranking?
What is your new distributor, is it made to run with a processor?
dusterdude
US
mark
gmc c15
Good questions on the distributor,ill have to get with the seller and ask.will advise when i get more info.thanks for the help.
hogdaddy
Alabama
mike
Scottsdale
Which distributor and coil are you using? MSD, ACCEL?
First thing you need to verify you have spark,take out a plug attach the plug wire clamp the plug body in a jumper cable other end of jumper cable to ground,crank and look for spark. 2nd Make sure you're distributor was stabbed correctly.If the problem isn't solved by then you need to find out what distributor and coil you are running,they don't all wire the same and don't all trigger the same.
FenderBanger
