Hard starting 6.2l diesel
79crewcab
Butterfield
Trevor
K20 crew cab
6.0l LS
I have an 82 sierra k20 with a 6.2l diesel that just cranks and smokes when trying to start it had sat for 15+years before i got it i dont believe its compression related being theirs only 27k miles on a reman engine i replaced fuel tank, lines,and put new 6.5l injectors in as well as high torque starter i assume only thing left could be a gunked up injection pump? When it cranks it smokes alot of white smoke and I give it a little shot of ether and it fires right off and runs and idles fine
PrairieDrifter
North Dakota
Mason
Suburban k10, bonanza k10, k30, c10, gmc 1/2ton
350, 350, 5.9L 12v Cummins, 350, 350,
6.2's really want all the glow plugs functioning well. Even in the summer.
If nothing else, make a little ether injection tube and run into the cab. Keep a can in the truck.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
What @PrairieDrifter said.
If it's smoking, the pump is pumping.
Stop ethering it. Fix the glow plugs. While you have them out, do a compression test to confirm the health of the engine.
rancher1913
Colorado
brian
c10, k5, k30
leroy diesel has replacement plugs and wires. mine went from starting ok and smoking a little to instant starts lots of power and no smoke. make sure you get the removal tool, those stupid plugs like to brake off inside the head without it
vr1967
Virgil
k1500
6.2L turbo
I would update to the 85-up glow plug relay as the 82-84 was not reliable, and is now hard to get parts for.
NLD79K10
Netherlands
Lars
White smoke on a cold diesel engine tends to be unburnt fuel being pumped straight out the exhaust, are your glow plugs working properly?
alex7915
