bobehud
- Sep 30, 2011
- St.Louis
- Bob
- 91' with early 80's drivetrain
- Suburban K3500
- 454 carbed
Most times its when the carb is in fast idle,can feel as well as hear it.
With basically a broken neck (fused all but one vertebrae ) i cant crawl under it.
But i have been fixing other peoples noises a long time.First thought was u-joint,second thought was trans mount,third and the expensive thought
was rear axle.Would not be the first time i have seen a fresh rearend have the pinon nut back off a tad.
Took it on the hiway run it up 75mph or so a just lifted let the chassis unload..didnt hear a thing, hard start from stop even enough to turn a tire and to a quick lift nothing,no noise.was not being silly was loading and unload rear axle.
All windows down,running next to concrete divider no 'bounce back' noise.
Lay it on me guys.
Lay it on me guys.
