Guage install now R20 wont crank?
30backs
Middle Ga
Scott
I installed a new set of gauges in to my 1988 cclb r20 and now it wont crank. It already had an existing set of gauges I just swapped in some new ones oil pressure, water temp and amp. All I can get to do is spin oven it wont even fire any ideas on what I could have knocked loose or what fuse I might have blown?
There is a fuse for the ECM & ignition system. It's labeled ECM/IGN - 10 amps - 3rd down from the top, left column.
Let us know how ya make out man if it was the fuse or not.
30backs
Middle Ga
Scott
I figured it out but it wasn't a fuse . It was the amp meter was wired up wrong dope
Good job and thanks for the results
