Guage cluster acting up in 1985 Chevy
Dyl0116
ONTARIO
Dyllenn
Ok so, this cluster f*** of a truck is driving me insane. First had no tail lights. So i wired them direct to switch to come on when switch is pulled. Then headlights/ running lights burnt out. I then changed the headlight switch and was back to normal. Now the truck has no dash lights, the oil and temp light on left side will not turn off (red) lights) and rest of lights don't work. When left signal is engaged, the signals outside the truck work, but inside they both flash as if hazards were engaged. When right signal light is triggered, again outside the truck it works, inside the truck it causes the fuel gauge to fluctuate. When turn of the key, the gas gauge drops an inch below E. What is going on, anyone else have issues similar. 1985 k10. I did change guage cluster as previous one the electrical circuit was a disaster.
robert8096
Goose Creek SC
Robert
Is the replacement cluster an exact replacement from the same year and optioned truck? IE did your old cluster have warning lights and you replaced it with a cluster with gauges. Did you get the cluster connector when you got the other gauge cluster? Different year clusters have different wiring pin outs. It could be that the wiring on the cluster connector is not correct for the cluster you put in. Could also be a cluster grounding issue.
83swb
CT
Hunter
83'
350/th350
When I disconnected my ground on my tail-light harness my blinkers and fuel gauge did the same thing. Sorry thats all I got.
robert8096
Goose Creek SC
Robert
Don't disconnect any grounds. Check to make sure the cluster is grounded.
83swb
CT
Hunter
83'
350/th350
That was the outcome of removing my bed and not reconnecting grounds afterward. Should have explained that better.
jackscott2005
