Got Rust?
echo7bravo
Alabama
Adam
K-10 stepside
350/Th400, 4.56 with 35" BFG MT
reason to cab swap.
echo7bravo
Alabama
Adam
K-10 stepside
Old cab off. Fuel sending units repaired. Ready to put new cab on.
And here comes the rain.
CSFJ
echo7bravo
Alabama
Adam
K-10 stepside
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Jeez. That old cab was either from Whitehorse, Yukon or it was submerged in salt water after a hurricane. That's horrible.
echo7bravo
Alabama
Adam
K-10 stepside
Nah, I think PO just neglected to keep up with waxing.
Big Chip
Michigan
Kevin
C35
Now I see why it's called Big Nasty! Are you going with the front sheetmetal from the donor truck or are you going to modify the new cab for your 86 sheetmetal?
350 w/203
Oh I don't know...a few curtains, some throw pillows and nobody'll notice. But DAM!
I like the Fred Flintstone look tho.
echo7bravo
Alabama
Adam
K-10 stepside
I’ve got a whole cab and doors going in using 86 front clip and inner fender wells. They were not originals they didn’t have rust LOL
Big Chip
Michigan
Kevin
C35
What year is the cab? I was asking because the hood hinges are different and I wasn't sure how you were going to accomplish that part. I know it can and has been done but I have no idea of the process to do it.
echo7bravo
Alabama
Adam
K-10 stepside
Cab is 1979. I have all the specs on where to cut the rectangular holes for the hinges to slide down into. Will be welding a reinforcing bracket for the hinges to bolt on to.
Also pulled the wiper mechanisms from the original cab so that it will all line up and come up through the cowl.
Everything will look like a 1986 when finished. Only exception is I have decided to keep the 79 dash. Door panels are coming from the 86 along with PW/L. But since the 79 dash is crack free and has tachometer....I opted not to swap steering column and dash.
echo7bravo
Alabama
Adam
K-10 stepside
It's good to see more of that nice donor truck going to good use.
And my vote goes to 70's front clip![/I
I was torn between modifying hinges/cowl area and sourcing a front clip. Then my son said he preferred the quad lights vs. the round eyes.
There isn’t any rust in hood or fenders. I am thinking they were replaced when someone tried to fill the gaping holes with body filler.
Total mess. At least the bed isn’t to rough! :)
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
I agree. I like my stacked headlights on the 87' and I don't think they look bad, but I like the sheetmetal from the older trucks so much better. The shape of the hood and the bumper are much more detailed, and I've always been a sucker for round bulbs in a square bezel on any car...
echo7bravo
Alabama
Adam
K-10 stepside
I hear ya! I Now have 2wd frame in my yard with a 350/Th350 screaming “build out a round eye hot rod”.
See if I don’t stumble onto a 70’s long bed to cut down next. LOL
alwaysbroken
