GMC-IH
dragstews
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
Where the oil temp probe is at is in the oil gallery feeding the main bearings ..
Constant moving flow of oil ...
The gauge should read pretty close to the actual temp ..
Working on nailing down a 25 row cooler ..
It may be more than what's needed, but for the dollar I'm giving for it ..
... Que Sera Sera ...
Oh.. so im confused, you want to move it or you want to have a second gauge or difference between the hot oil and returned oil?
dragstews
Jesse
R-100
406 ci SBC
I'll leave it where it's at ...
Do think for the most actual oil temp would be having the gauge installed near the bottom of the oil pan ...
Not wanting to drill a hole in the aluminum pan, did think about drilling a hole in the drain plug, having the wire running down the side of the pan vetoed that idea ..
But with the oil cooler on line don't think I'll be having a heat issue ..
Here's the cooler ..
Do think it may be overkill ..
  • 14.5" wide core (310mm)
  • 25 rows or 7.5" (190.5mm) core height
  • Made in Sweden
Made by Setrab
They offers some of the highest quality oil coolers on the market. Lightweight and efficient, they are an excellent choice for cooling high performance street and race engines, transmissions and differentials.
Also think having a oil temp gauge is a bit overkill too ...
That idea is just to have a visual on what's going on .. Be nice to know the conditions of vital points of the motor under high stress loads ..
I pull two trailers with this old truck ..
30' fifth wheel RV and a 16' box trailer hooked to the RV ..
Kind of looks like Jeb Clampett traded up ... Eek
For a few bucks more can get this 30 row cooler ..
5 more rows than the other cooler ..
i would simply go based on the ease of mounting in your situation, what fits better
dragstews
Jesse
R-100
406 ci SBC
i would simply go based on the ease of mounting in your situation.
Won't matter a great deal cause whatever cooler I come up with will need homespun brackets to be made up ..
Got all kinds of room under the radiator, being in the air flow will be a huge plus ..
A word on the oil temp gauge, coming from Canada ..
It's stuck in customs, been a few days and hasn't moved a foot ...
Wonder if Trump had a hand in this delay ??
Do think that Boy could tear up a crowbar with a rubber hammer !
I'm not much into politics, in fact my political involvement boils down to a bumper stricter ...
And it says ...
"I rather go hunting with Dick Cheney than ride with Ted Kennedy"
Update on the Canadian package ..
It's moving, made it to Syracuse, New York ..
Well, it's heading South .. Yippee
It's in Jacksonville, Fl ...
Might have it in my greasy hands tomorrow ..
Hope that it fits the spot I picked out ?
Not a lot of room in the glovebox due to it being cut down for having room for the A/C unit ...
dragstews
Jesse
R-100
406 ci SBC
May pull the trigger for a cooler that has a fan ..
Adding a control to switch the fan on would be a good idea ..
And it says ...
my favorite moment of 2006 (2nd grade for me) was when the vice president of the united states mistook his buddies face while he was near him as a flightless, ground-walking quail who were unafraid of humans and shot him with birdshot
and then THAT GUY(friend) APOLOGIZED TO HIM (vice president)
"thats some real clint eastwood ****"-will farrel in the comedy special "Youre Welcome America" where he reflects on the 8 years of the bush admin pretending to be president bush
dragstews
Jesse
R-100
406 ci SBC
Found a nice spot for the oil temp gauge, under it is the display for the trans temp ..
Worked out better than I expected ..
Kinda liking this gauge cause at 250 degrees it starts to flash ..
At that temp it's almost like ;
'Oops too Late'
The ideal temperature for a 454 BBC engine's oil is generally considered to be between 195°F and 220°F. This range allows for efficient lubrication and cooling of the engine's internal components.
While some experts recommend a slightly higher range of 230°F to 260°F, the majority agree that 195-220°F is ideal.
Temperatures above 275°F can start to degrade conventional motor oil.
.... THEN ....
.... FAST ....
dragstews
Jesse
R-100
406 ci SBC
Kinda stuck with moving forward on the 496" motor build ..
I'm needing to buy some tooling to finish prepping the block ..
Been in the mode of saving up the money to get these two items ..
Should have them here by the end of next week ..
The block won't be ready for final assembly after working with these tools, but will be a few steps closer than it was.
dragstews
Jesse
R-100
406 ci SBC
Redo work is on the table ..
Was trying to match the grain & color that the steering wheel has ..
After doing the work on the dash, seen that it was a bit to dark ..
Going to try again ..
Different base color ..
Might be getting closer to a match ??
Going forward with job, soon to print the grain on ..
dragstews
Jesse
R-100
406 ci SBC
Did some work to the 496 block ...
One word sums up this job .....
..... " Groovy " .....
Hoping to finish honing soon ..
dragstews
Jesse
R-100
406 ci SBC
It happens !! .. So says Forrest Gump ..
( Somebody Else put on the Sh )
Been waiting for a set of ARP heads bolt studs to show up from 'Summit Racing' for a few days ..
They came in today, wrong ones ..
Kind of thought they would be cause the salesperson was having a hard time looking up the right number for a stock 454 big block with stock 781 cast iron heads .. Eek ..
No biggie ..
Called them and they're sending a call tag for the wrong ones and sending me out the right ones ..
Can't get in a hurry when building a hot-rod motor using aftermarket parts ... Just another hiccup to contend with, it's all part of it ..
dragstews
Jesse
R-100
406 ci SBC
On a side note ..
I have that lifter bore grooving tool up for sale ..
Would love to keep it for future jobs, but do need the money to buy another tool ..
Oliver90_08
